| EMN, INRIA | project Obasco |
RUNNING,
READY, BLOCKED, and TERMINATED are
actually derived from event types defined in terms of the tuple state
classes (RUNNING,RUNNING), (READY,READY),
(READY,BLOCKED), (BLOCKED,READY),
(BLOCKED,BLOCKED), and (TERMINATED,TERMINATED),
in which the first component represents the policy's perspective on the
state class of the process and the second component represents the kernel's
perspective on the state class of the process. Specifically, these are
defined as follows:
(RUNNING,RUNNING): Both the policy and the kernel
consider the process to be running.
(READY,READY): Both the policy and the kernel
consider the process to be able to run. The bossa.schedule
event handler is invoked if there is any process in this state class, and
must elect one such process.
(READY,BLOCKED): The policy is willing to run the
process, but the process is blocked in the kernel. A running process that
blocks ends up in this state class. A process that is in this state class
and unblocks is returned to the (READY,READY), implying that
it may be elected again.
(BLOCKED,READY): The process is not blocked waiting for
anything in the kernel, but the policy is not willing to run it. This
state class is used, for example, in a periodic policy when a process
should not run until the beginning of its next period.
(BLOCKED,BLOCKED): Both the policy and the kernel
consider the process to be unable to run. This state class may be used
when a process has blocked in the kernel and receives a notification via an
interrupt that its allotted elapsed time has expired within the current
period. It is not possible to move directly from this state class to
(READY,READY). Instead, the policy and the kernel must each
indicate that the process can be run, causing the process to first pass
through the (READY,BLOCKED) or (BLOCKED,READY)
state class.
(TERMINATED,TERMINATED): Both the policy and the kernel
consider the process to be terminated.
(X,READY) and
(X,BLOCKED) state classes, for any X due to
block.* and unblock.* events (not
unblock.timer.*), while processes move between the
(READY,X) and (BLOCKED,X) state
classes due to the timing-related events system.clocktick and
unblock.timer.*.
To avoid confusion about which tuple component is which, atomic names are
used for these various state classes in a Bossa policy. The
correspondences are as follows. These state classes can be used by giving
the argument -pb to the Bossa compiler.
(RUNNING,RUNNING) is written as
RUNNING.
(READY,READY) is written as
READY.
(READY,BLOCKED) is written as
POLICY_BLOCKED.
(BLOCKED,READY) is written as
KERNEL_BLOCKED.
(BLOCKED,BLOCKED) is written as
KERNEL_POLICY_BLOCKED.
(TERMINATED,TERMINATED) is written as
TERMINATED.
The event types defined in terms of RUNNING,
derived from the types below using the following translation:
(RUNNING,RUNNING)/RUNNING becomes
RUNNING.
(READY,READY)/READY becomes
READY.
(READY,BLOCKED)/POLICY_BLOCKED becomes
BLOCKED.
(BLOCKED,READY)/KERNEL_BLOCKED becomes
BLOCKED.
(BLOCKED,BLOCKED)/KERNEL_POLICY_BLOCKED becomes
BLOCKED.
(TERMINATED,TERMINATED)/TERMINATEDbecomes
TERMINATED.
The events are as follows:
The event types defined in terms of these state classes are as follows,
using the atomic names for conciseness. As compared to the event types
defined in terms of RUNNING, READY,
BLOCKED, and TERMINATED, the only differences are
in the type rules that refer to BLOCKED. We thus explain only
these cases, and refer the reader to the description
of the simpler event types for further information. While these event
types are more complex than those defined in terms of RUNNING,
READY, BLOCKED, and TERMINATED, they
can also detect more errors, in particular in policies where there are
multiple reasons why a process can block, and when this blocking can occur
in interrupt handlers.
An important notion in the checking of event types is the identification of
those that derive from "quasi-sequences". A quasi sequence occurs when an
interrupt occurs within the normal flow of execution and causes the running
process to be preempted in some way. Types marked as arising from
quasi-sequences (marked with -q>) are only used when an
interrupt handler can create the input state.
POLICY_BLOCKED state. Only this variant of
BLOCKED is possible; the others would imply that the source
process is unable to run from the point of view of the kernel, and thus is
not able to create a new process.
[tgt in NOWHERE, src in RUNNING] ->
{ [tgt in READY], [[src, tgt] in READY] }
[[] = RUNNING, src in READY, tgt in NOWHERE] -q>
[tgt in READY]
[[] = RUNNING, src in POLICY_BLOCKED, tgt in NOWHERE] -q>
[tgt in READY]
The rule for the initial process is unchanged.
[tgt in NOWHERE] -> [tgt in READY, src in NOWHERE]
KERNEL_BLOCKED state or a KERNEL_POLICY_BLOCKED
state.
{ [tgt in KERNEL_BLOCKED], [tgt in KERNEL_POLICY_BLOCKED] } -> [tgt in TERMINATED]
RUNNING state or a READY state, then it is put
in a KERNEL_BLOCKED, according to the first two rules. If the
target process is in a POLICY_BLOCKED state, meaning that the
policy does not want to run it, then it is now the case that neither the
kernel nor the policy wants the process to run. Thus, the process is put
in a KERNEL_POLICY_BLOCKED state.
As compared to the type rules defined in terms of RUNNING,
READY, BLOCKED, and TERMINATED, in
all of the type rules below, the target process must change state, due to
the distinction between POLICY_BLOCKED and
[tgt in RUNNING] -> [tgt in KERNEL_BLOCKED] [[] = RUNNING, tgt in READY] -q> [tgt in KERNEL_BLOCKED] [[] = RUNNING, tgt in POLICY_BLOCKED] -q> [tgt in KERNEL_POLICY_BLOCKED]
KERNEL_BLOCKED state class, then the process is now able to
run, and thus put in the READY state class. Preemption is
allowed in this case, as indicated by the second rule. On the other hand,
if the process is blocked both from the point of view of the kernel and
from the point of view of the policy, ie in the
KERNEL_POLICY_BLOCKED state class, then it must remain blocked
from the point of view of the policy, and is thus put in the
POLICY_BLOCKED state class. Preemption is bnot allowed in
this case, because the policy is not willing to run the target process.
Fibally, if the target process is not actually blocked from the kernel's
point of view, then no state change is allowed, as indicated by the last
type rule.
the distinction between KERNEL_POLICY_BLOCKED and
POLICY_BLOCKED.
[tgt in KERNEL_BLOCKED] -> [tgt in READY]
[p in RUNNING, tgt in KERNEL_BLOCKED] -> [[p,tgt] in READY]
[tgt in KERNEL_POLICY_BLOCKED] -> [tgt in POLICY_BLOCKED]
{ [tgt in RUNNING], [tgt in READY], [tgt in POLICY_BLOCKED] } -> []
unblock.timer.* and to
unblock.timer.name, where name is the name of a
timer declared in the process/scheduler structure
of the current scheduler. In the first rule, processes can change state
within a state class, regardless of the state class of the target process.
Such state changes are allowed by all of the other rules as well. The
second rule additionally specifies that if the target process is initially
running, then it can move to a state in the READY or
POLICY_BLOCKED state class. It cannot move to a state of the
KERNEL_BLOCKED or the KERNEL_POLICY_BLOCKED state
class, because the exipiration of a timer created by the policy does not do
anything to make the process unable to run from the kernel's point of view.
The next two rules allow the target process to move between the
READY and POLICY_BLOCKED state classes. Again
runnability of the process does not change from the point of view of the
kernel, and so the process cannot move to the KERNEL_BLOCKED
state class or the KERNEL_POLICY_BLOCKED state class. In the
next two rules, the target process can move between the
KERNEL_BLOCKED and the KERNEL_POLICY_BLOCKED state
classes. Here, the process remains unable to run from the kernel's point
of view, but the policy can change its mind about whether it would like to
allow the process to run when it becomes able to do so. In the final rule,
if the target process ends up in a READY state, then the
running process can additionally be preempted.
{ [tgt in RUNNING], [tgt in READY], [tgt in POLICY_BLOCKED], [tgt in KERNEL_BLOCKED], [tgt in KERNEL_POLICY_BLOCKED] } ->
[READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!]
[tgt in RUNNING] ->
{ [tgt in READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!],
[READY!, tgt in POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!] }
[tgt in READY] ->
[tgt in POLICY_BLOCKED] ->
[READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, tgt in KERNEL_POLICY_BLOCKED!]
[READY!, POLICY_BLOCKED!, tgt in KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!]
{ [p in RUNNING, tgt in READY], [p in RUNNING, tgt in POLICY_BLOCKED] } ->
[[p,tgt] in READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!]
The following type rules apply to unblock.timer.name,
where name is the name of a timer declared as a global variable in
the current scheduler. The first rule states that if there is any process
in any of the state class, then transitions are allowed within all of the
state classes. The next five rules allow transitions between state classes
analogous to the transitions of the target process in the rules above.
Note that transitions are only allowed from a single state class to another
single state class; other processes must remain within their current state
classes. This can be seen as a limitation. The last rule allows
preemption of the running process when processes move from the
POLICY_BLOCKED state class to the READY state
class. In contrast to the case where the timer is associated with a
specific procss, there is no case for preemption when processes move within
the READY state class. This case is subsumed by the second
rule, which allows the running process to move to a READY
state and arbitrary transitions within the READY state class.
{ [p in RUNNING], [p in READY], [p in POLICY_BLOCKED], [p in KERNEL_BLOCKED], [p in KERNEL_POLICY_BLOCKED] } ->
[p in RUNNING] ->
{ [p in READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!],
[READY!, p in POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!] }
[p in READY] ->
[p in POLICY_BLOCKED] ->
[p in KERNEL_BLOCKED] ->
[READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, p in KERNEL_POLICY_BLOCKED!]
[p in KERNEL_POLICY_BLOCKED] ->
[READY!, POLICY_BLOCKED!, p in KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!]
[p in RUNNING, p1 in POLICY_BLOCKED] ->
[[p,p1] in READY!, POLICY_BLOCKED!, KERNEL_BLOCKED!, KERNEL_POLICY_BLOCKED!]
READY
state, implying that the process can be elected if there is no other
eligible process, or by putting it in a POLICY_BLOCKED state,
implying that the process cannot be elected until it is moved to a
READY state by some subsequent event.
KERNEL_BLOCKED and KERNEL_POLICY_BLOCKED are
not options, because running out of time does not make a process unable to
run from the kernel's point of view (eg, the process is not waiting for any
resource).
[tgt in RUNNING] -> { [], [tgt in READY], [tgt in POLICY_BLOCKED] }
POLICY_BLOCKED when a handler for an event occurring in an
interupt has decided to block the process just as it was planning to
yield. The compiler only takes this type into account if there is such an
interrupt handler.
[tgt in RUNNING] -> [tgt in READY] [[] = RUNNING, tgt in READY] -q> [tgt in READY] [[] = RUNNING, tgt in POLICY_BLOCKED] -q> []
[[] = RUNNING, p in READY] -> [p in RUNNING, READY!]
